JMP 12 Online Documentation (English)
Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Specialized Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13.2 Online Documentation
Scripting Guide
Compatibility Notes
• Deprecated JSL
Deprecated JSL
Please begin using the new following new JSL commands for rotating axis labels and setting fonts. Existing scripts continue to work. However, the old messages and syntax will be discontinued in the future.
Rotated Labels
The
<<Rotated Labels
message for
Axis Box()
has been replaced with
<<Label Orientation
ab<<Label Orientation( "Automatic" );
ab<<Label Orientation( "Horizontal" );
ab<<Label Orientation( "Vertical" );
ab<<Label Orientation( "Perpendicular" );
ab<<Label Orientation( "Parallel" );
ab<<Label Orientation( "Angled" );
Set Font() Arguments
The following formats are deprecated for
ContourSeg()
TextSeg()
HierBox()
ColListBox()
FilterColSelector()
ListBoxBox()
NumberEditBox()
OutlineBox()
TextBox()
, and
TextEditBox():
obj<<Set Font( {"Name", size, style, angle} );
obj<<Set Font( Face( "Name" ), Size( size ), Style( style ) );
Use the following formats, which work for all display boxes that have font properties:
obj<<Set Font( "Name", size, style, angle );
obj<<Set Font Name( "Name" ) << Set Font Size( size ) << Set Font Style( style );
