Use the cut, copy, and paste keyboard shortcut commands or right-click a highlighted part of the formula and select Cut, Copy, or Paste from the menu.
Use the keyboard arrow keys to select expressions for editing. You can also use the arrow keys to view the formula’s order of precedence when either parentheses or the boxing option are not present. (See Hide and Show Boxing.)
Clicking an operator (+, –, *, ÷) in an expression selects the operator and its operands. A red box appears around the items. Once an operator is selected:
Click Apply, and the new values fill the data table column automatically.
You can cut or copy any expression or an entire formula and paste it into another formula display. Use the cut, copy, and paste shortcut commands or right-click a highlighted part of the formula and select Cut, Copy, or Paste from the menu. The following aspects apply when you cut, copy, and paste a formula:
Note: Press the SHIFT key on your keyboard, and then click the red triangle to reveal a command called Copy As SAS Formula.
