Select Rows > Add Rows.
Click OK.
Select Cols > New Column. You can then specify more details about the column. You can also add subsequent columns by clicking Next. See The Column Info Window.
Note: When you initially create a column, you can choose to fill it with initial data values. See Fill in Initial Data Values in The Column Info Window. However, after you modify the cells, this option no longer appears.
Using the Add Multiple Columns command to define multiple columns is different from using the New Column command. All of the columns that you add using the Add Multiple Columns window have the same data type. Right-clicking anywhere to the right of the last column in a data table to add multiple columns defaults to After Last Column.
(Optional) Change the Column prefix.
7.
Click OK.
Sums the values of cells in columns height and weight located in the same row as the cell that you entered the expression.
Displays the value found in row 1 of the height column
