Select Analyze > Consumer Research > Factor Analysis.
Select all of the continuous columns and click Y, Columns.
Click OK.
Factoring Method as Maximum Likelihood
Prior Communality as Common Factor Analysis
Rotation Method as Varimax
The report lists the communality estimates, variance, significance tests, rotated factor loadings, and a factor loading plot. Note that in the Factor Loading Plot, Factor 1 relates to the Carbon Tetrachloride-Chloroform-Benzene-Hexane cluster of variables, and Factor 2 relates to the Ether–1-Octanol cluster of variables. See Factor Analysis Model Fit Options for details of the information shown in the report.
Launch the Factor Analysis platform by selecting Analyze > Consumer Research > Factor Analysis. This example uses the Solubility.jmp sample data table.
Lists different methods for fitting the model. For details about the methods, see the Multivariate chapter in the Multivariate Methods book.
Lists the scaling methods for performing the factor analysis based on Correlations (the same as Principal Components), Covariances, or Unscaled.
