JMP 12 Online Documentation (English)
Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Specialized Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13.2 Online Documentation
Control Chart Builder
• Excluded and Hidden Samples
The following bullets summarize the effects of various conditions on samples and subgroups:
Excluded subgroups are not used in the calculations, but appear in the chart (although dimmed).
Hidden observations are used in the calculations, but do not appear in the chart.
For partially excluded subgroups, if one or more observations within a subgroup is excluded, and at least one observation within the subgroup is included, the excluded observation is not included in the calculations of either the point statistic or the limits.
Checks for negative and non-integer data happen on the entire data (even excluded values).
Tests continue to apply to all excluded subgroups. Excluded samples are flagged when tests are turned on.
