There are a number of important differences between JMP and Excel or other spreadsheet applications.
Formulas are applied only to entire columns. Calculating Values with Formulas in Working with Your Data describes how to use formulas.
Understanding Modeling Types in Analyzing Your Data describes how data type influences platform results.
JMP does not have the concept of worksheets. Each data table is a separate .jmp file and appears in a separate window.
