To change the default conversion method, select File > Preferences (or JMP > Preferences on Macintosh). On the General page, deselect Use SPSS labels for column names during import. Variable names are then imported automatically as column headings.
The value labels that you defined in the SPSS file are saved as Value Labels column properties. The value label then appears in each data table cell instead of the original value. For details about Value Label properties, see Value Labels in The Column Info Window.
SPSS can assign certain values in a variable to be treated as missing for analyses. For example, the value 64 could be regarded as missing for a Height variable. Then, the calculation of the distribution of height would ignore values of 64. When you import SPSS into JMP, these values are included in the Missing Value Codes column property for the appropriate variable.
Select File > Open.
(Optional) To specify the column headings, select one of the following Set JMP column names from options:
SPSS Labels creates column headings from SPSS labels.
SPSS Variable Names creates column headings from variable names.
Click Open.
Select File > Open.
Deselect Use SPSS Labels as Headings to convert variable names to column headings.
Select Use SPSS Labels as Headings to convert labels to column headings.
Click Open.
