Triple-S (SSS) is a specification for survey data. The survey data is stored in a pair of files: .xml or .sss, and a .csv, .dat, or .asc file. The .xml or .sss file defines the variables and describes the survey. The accompanying .csv, .dat, or .asc file contains the data gathered from each respondent.
Variable labels are converted to column headings by default. To convert variable names to column headings, deselect Use Triple-S Labels as Headings in the JMP General preferences.
Note: On Macintosh, rename the .xml file as an .sss file before you open it. The Macintosh operating system does not recognize the .xml file as a Triple-S file. However, you can open the .xml file using the TripleS Import() function in a script. See the JSL Syntax Reference for details.
Select File > Open.
On Windows, select Triple-S Survey Files from the File name list.
Click Open.
