JMP 12 Online Documentation (English)
Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Specialized Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13.2 Online Documentation
Using JMP
Get Started
• JMP Personalization Window
The very first time that you open JMP, the Personalization window appears. This window also appears if you re-install JMP and you do not have an existing preference file.
This window contains two panels:
Menu Options
Deselect any menu options that you want to hide from your JMP view.
General Options
Select from common general preferences. For more information about these preferences, see
General
in JMP Preferences
