Single-variable graphs, or univariate graphs, let you look closely at one variable at a time. When you begin to look at your data, it’s important to learn about each variable before looking at how the variables interact with each other. Univariate graphs let you visualize each variable individually.
Histograms, for continuous variables
Bar Charts, for categorical variables
This example uses the Companies.jmp data table, which contains data on profits for a group of companies.
To answer these questions, use a histogram of Profits ($M).
Distribution Window for Profits ($M)
Click OK.
Histogram of Profits ($M)
One company has significantly higher profits than the others, and might be an outlier. An outlier is a data point that is separated from the general pattern of the other data points.
Quantiles and Summary Statistics reports. These reports are discussed in Analyzing Distributions in Analyzing Your Data.
This example uses the Companies.jmp data table, which contains data on the size and type of a group of companies.
Click OK.
The additional summary output gives detailed frequencies. This report is discussed in Distributions of Categorical Variables in Analyzing Your Data.
For example, suppose that you want to see the distribution of company size for the pharmaceutical companies. Click the Pharmaceutical bar in the Type bar chart, and the pharmaceutical companies are highlighted on the Size Co bar chart. Clicking Bars shows that although most companies in this data table are small, most of the pharmaceutical companies are medium or big.
