JMP 12 Online Documentation (English)
Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Specialized Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13.2 Online Documentation
Using JMP
Enter and Edit Data
• Resizing Rows and Columns
To resize rows
Resize rows by dragging one of the row borders. All rows are resized to the same height. Graphics that display inside each cell shrink based on the row height.
To resize columns
To resize a column, drag the column border to the right or left.
To resize several columns to the same width, follow these steps:
Select the columns that you want to resize.
Press the Control key (Windows) or Option key (Macintosh) and drag one of the column borders. All columns are resized to the same width.
