JMP 12 Online Documentation (English)
Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Specialized Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13.2 Online Documentation
Standard Least Squares Report and Options
• Response Options
Response Options
Red triangle menu options for the response give you the ability to customize reports according to your needs.
Description of Response Options
Regression Reports
Shows basic reports and report options. See
Regression Reports
Estimates
Provides options for further analyses relating to parameter estimates. See
Estimates
Effect Screening
Provides reports and plots for identifying significant effects. See
Effect Screening
Factor Profiling
Provides profilers, interaction, and cube plots to examine how the response is related to the model terms. Also provides a plot and report for fitting a Box-Cox transformation. See
Factor Profiling
Row Diagnostics
Provides plots and reports for examining residuals. Also reports the PRESS statistic and provides a Durbin-Watson test. See
Row Diagnostics
Save Columns
Saves model results as columns in the data table, except for Save Coding Table, which saves results in a separate data table. See
Save Columns
Model Dialog
Shows the completed Fit Model launch window for the current analysis.
Effect Summary
Shows the interactive Effect Summary report that enables you to add or remove effects from the model. See
Effect Summary Report
Script
Contains options that are available to all platforms. See the
Using JMP
book.
