Each time you use JMP is called a session. A saved session is a JSL script that re-opens documents and re-runs analyses to restore JMP’s state when the session script was saved. A saved session can help get you back to a previous state without having to manually re-open files and re-run analyses.
If you are an advanced user, it is important to understand what session information is preserved in a saved session. Any documents (such as data tables, scripts, and journals) that have been saved are re-opened. JMP windows that support script saving are re-run (equivalent to clicking the red triangle in a report and selecting Script > Redo Analysis). Side effects of running scripts, such as global variable values or custom windows, are not saved. The state of highly interactive analyses is also not saved.
The most common use of saved sessions is to save the state when JMP exits so it can be restored when JMP restarts. By default, JMP asks whether you would like to save the state of your session each time you exit the program (Saving Session Upon Exiting). This enables you to quit JMP, and then return to it later without having to open the files with which you were previously working.
To always save the session upon exiting, select Do not ask me again about saving the session and click Yes or No. This option also prevents JMP from saving the session upon exiting,
Choose File > Preferences.
Select the General icon.
Next to the Save the session when exiting option, choose when you want JMP to save the session. Always, never, and prompt whether you want to save are the options.
Select File > Save Session Script.
Another way of manually saving a session is by creating a journal of each session. A journal can be a notebook-style or project-style file. With it, you can collect references to files in a project, develop presentation launch pads, document projects, and store many scripts in one place. See JMP Journals for details.
Select File > New > Journal. Or, to append your open files to an existing journal, open that journal.
Right-click in the empty journal and select Add All Open Files.
