JMP 12 Online Documentation (English)
Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Specialized Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13.2 Online Documentation
Profilers
• Surface Plot
Surface Plot
Explore Contours of Responses across Three Factors
The Surface Plot platform functions both as a separate platform and as an option in model fitting platforms. Up to four dependent surfaces can be displayed in the same plot. The dependent variables section, below the plot, has four rows that correspond to the four surfaces. Depending on what you choose to view (sheets, points, isosurfaces, or density grids) and whether you supply a formula variable, different options appear in the dependent variables section.
Example of a Surface Plot
Contents
Surface Plot Overview
Launch the Surface Plot Platform
Plotting a Single Mathematical Function
Plotting Points Only
Plotting a Formula from a Column
Isosurfaces
Surface Plot Platform Options
Appearance Controls
Independent Variables
Dependent Variables
Surface Plot Controls and Settings
Rotate
Axis Settings
Lights
Sheet or Surface Properties
Other Properties and Commands
Keyboard Shortcuts
