The Alias Matrix gives coefficients that indicate the degree to which the model parameters are biased by effects that are potentially active, but not in the model. For this reason, it is related to the Model Matrix. The Alias Matrix is also used in defining alias optimality. See Alias Optimality in Custom Designs.
