Select DOE > Mixture Design.
Click the ABCD Design button.
Keep the Same: The rows (runs) in the output table appear as they do in the Factor Settings panel.
Sort Left to Right: The rows (runs) in the output table appear sorted from left to right.
Randomize: The rows (runs) in the output table appear in a random order.
Sort Right to Left: The rows (runs) in the output table appear sorted from right to left.
Randomize within Blocks: The rows (runs) in the output table appear in random order within the blocks that you set up.
8.
Click Make Table.
