Example of a Multivariate Report
Select Help > Sample Data Library and open Solubility.jmp.
Select Analyze > Multivariate Methods > Multivariate.
Select all columns except Labels and click Y, Columns.
In most of the analysis options, a missing value in an observation does not cause the entire observation to be deleted. However, the Pairwise Correlations option excludes rows that are missing for either of the variables under consideration. The Simple Statistics > Univariate option calculates its statistics column-by-column, without regard to missing values in other columns.
