JMP 12 Online Documentation (English)
Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Specialized Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13.2 Online Documentation
Scripting Guide
• Three-Dimensional Scenes
Scripting in Three Dimensions
JSL includes commands for scripting three-dimensional scenes derived from OpenGL. Although not a complete OpenGL implementation, JSL’s 3-D scene commands enable complex, interactive plots to be constructed and viewed. The Surface Plot platform in JMP is built using JSL scene commands.
Sample Three-Dimensional Shapes
Contents
About JSL 3-D Scenes
JSL 3-D Scene Boxes
Setting the Viewing Space
Setting Up a Perspective Scene
Setting up an Orthographic Scene
Changing the View
The Translate Command
The Rotate Command
The Look At Command
The ArcBall
Graphics Primitives
Primitives Example
Controlling the Appearance of Primitives
Other uses of Begin and End
Drawing Spheres, Cylinders, and Disks
Drawing Text
Using the Matrix Stack
Lighting and Normals
Creating Light Sources
Lighting Models
Normal Vectors
Shading Model
Material Properties
Alpha Blending
Fog
Example
Bézier Curves
Using the Mouse
Arguments
