• JMP 12 Online Documentation (English)
    • Discovering JMP
    • Using JMP
    • Basic Analysis
    • Essential Graphing
    • Profilers
    • Design of Experiments Guide
    • Fitting Linear Models
    • Specialized Models
    • Multivariate Methods
    • Quality and Process Methods
    • Reliability and Survival Methods
    • Consumer Research
    • Scripting Guide
    • JSL Syntax Reference
    • JMP iPad Help
    • JMP Interactive HTML
  • Capabilities Index
  • JMP 13.2 Online Documentation
JMP Support 919.677.8008 (US)
Documentation Feedback
Your feedback is important to us. us any comments about our documentation.
Specialized Models • Time Series Analysis
Fit Time Series Models and Transfer Functions
The Time Series platform lets you explore, analyze, and forecast univariate time series. A time series is a set y1, y2, ... ,yN of observations taken over a series of equally-spaced time periods. The analysis begins with a plot of the points in the time series. In addition, the platform displays graphs of the autocorrelations and partial autocorrelations of the series. These indicate how and to what degree each point in the series is correlated with earlier values in the series.
You can interactively add:
Variograms
a characterization of process disturbances
AR coefficients
autoregressive coefficients
Spectral Density Plots
versus period and frequency, with white noise tests.
These graphs can be used to identify the type of model appropriate for describing and predicting (forecasting) the evolution of the time series. The model types include:
ARIMA
autoregressive integrated moving-average, often called Box-Jenkins models
Seasonal ARIMA
ARIMA models with a seasonal component
Smoothing Models
several forms of exponential smoothing and Winter’s method
Transfer Function Models
for modeling with input series.
Contents
Launch the Platform
Time Series Commands
Modeling Reports
ARIMA Model
Seasonal ARIMA
ARIMA Model Group
Transfer Functions
Smoothing Models
