Consider the data from Daganzo, found in Daganzo Trip.jmp. This data set contains the travel time for three transportation alternatives and the preferred transportation alternative for each subject.
A partial listing of the data set is shown in Partial Daganzo Travel Time Table for Three Alternatives.
Each Choice number listed must first be converted to one of the travel mode names. This transformation is easily done by using the Choose function in the formula editor, as follows.
Select Cols > New Column.
Click Conditional under the Functions (grouped) command, select Choose, and press the comma key twice to obtain additional arguments for the function.
6.
Click Choice for the Choose expression (expr), and double click each clause entry box to enter “Subway”, “Bus”, and “Car” (with the quotation marks) as shown in Choose Function for Choice Mode Column of Daganzo Data.
7.
Click OK in the Formula Editor window.
8.
Click OK in the New Column window.
The new Choice Mode column appears in the data table. Because each row contains a choice made by each subject, another column containing a sequence of numbers should be created to identify the subjects.
9.
10.
Specify the Column Name as Subject.
11.
12.
Click OK.
A partial listing of the modified table is shown in Daganzo Data with New Choice Mode and Subject Columns.
For the Output table name, type Stacked Daganzo. Type Travel Time for the Stacked Data Column and Mode for the Source Label Column.
Click OK.
A partial data table is shown in Partial Subset Table of Stacked Daganzo Data. Note the default table name is Subset of Stacked Daganzo.
For the Response Data Table, you need the Subject and Choice Mode columns, but you also need a column for each possible choice.
Select Tables > Subset.
Select Cols > Add Multiple Columns.
7.
For the Column prefix, type Choice. Type 3 next to How many columns to add. Click Numeric and select Character.
8.
Click OK.
9.
Type “Bus” (without quotation marks) in the first row of Choice 1. Right-click the cell and select Fill > Fill to end of table.
10.
Type “Subway” (without quotation marks) in the first row of Choice 2. Right-click the cell and select Fill > Fill to end of table.
11.
Type “Car” (without quotation marks) in the first row of Choice 3. Right-click the cell and select Fill > Fill to end of table.
Now that you have separated the original Daganzo Trip.jmp table into two separate tables, you can run the Choice Platform.
Select Analyze > Consumer Research > Choice.
Click Run Model.
The resulting parameter estimate now expresses the utility coefficient for Travel Time and is shown in Parameter Estimate for Travel Time of Daganzo Data.
Rather than creating two or three tables, it can be more practical to transform the data so that only one table is used. For the one-table format, the subject effect is added as in the previous example. A response indicator column is added instead of using three different columns for the choice sets (Choice 1, Choice 2, Choice 3). The transformation for the one-table scenario includes the following steps.
Create or open Stacked Daganzo.jmp from the Stack the Data steps shown in Example of Transforming Data to Two Analysis Tables.
Type Response as the Column Name.
Select the column Choice Mode for the expression (expr).
7.
Enter “=” and select Mode.
8.
9.
10.
11.
12.
Select Analyze > Consumer Research > Choice to open the launch window and specify the model as shown in Choice Dialog Box for Subset of Stacked Daganzo Data for One-Table Analysis.
13.
Click Run Model.
14.
Select Yes to obtain the parameter estimate expressing the utility Travel Time coefficient, shown in Parameter Estimate for Travel Time of Daganzo Data from One-Table Analysis.
