Once your data is in a data table, you can create graphs or plots, and perform analyses. All features are located in platforms, which are found primarily on the Analyze or Graph menus. They are called platforms because they do not just produce simple static results. Platform results appear in report windows, are highly interactive, and are linked to the data table and to each other.
The platforms under the Analyze and Graph menus provide a variety of analytical features and data exploration tools.
Click OK to create the report window that contains your graphs and statistical analyses.
The following example shows you how to perform a simple analysis and customize it in four steps. This example uses the Companies.jmp file sample data table to show a basic analysis of the variable Profits ($M).
Select Analyze > Distribution to open the Distribution launch window.
The variable Profits ($M) appears in the Y, Columns role. See Assign Profits ($M) for the completed window.
Assign Profits ($M)
Click OK.
Click the red triangle next to Profits ($M) to see a menu of report options.
Deselect Outlier Box Plot to turn the option off.
Enter 500 in the Specify Hypothesized Mean box.
Click OK.
Platform results are connected to the data table. The histogram in Connection between Platform Results and Data Table shows that a group of companies makes a much higher profit that the others. To quickly identify that group, click on the histogram bar for them. The corresponding rows in the data table are selected.
