Scripting Guide > Data Structures > Associative Arrays in JSL Scripts > Associative Arrays in Set Operations
Publication date: 03/03/2025
In JSL, you can use associative arrays to perform set operations. The following examples show how to take a union of two sets, a difference of two sets, and an intersection of two sets.
First, create three sets and view them in the log:
set_y = Associative Array( {"chair", "person", "relay", "snake", "tripod"} );
set_z = Associative Array( {"person", "snake"} );
set_w = Associative Array( {"apple", "orange"} );
// write the sets to the log
Write(
	"\!NExample:\!N\!tset_y = ",
	set_y << Get Keys,
	"\!N\!tset_z = ",
	set_z << Get Keys,
	"\!N\!tset_w = ",
	set_w << Get Keys
Example:
set_y = {"chair", "person", "relay", "snake", "tripod"}
set_z = {"person", "snake"}
set_w = {"apple", "orange"}
Union Operation
To find the union of two sets, insert one set into the other:
set_z << Insert( set_w );
Write( "\!N\!NUnion operation (set_w, set_z):,\!N\!tset_z = ", set_z << Get Keys );
set_z = {"apple", "orange", "person", "snake"}
Difference Operation
To find the difference of two sets, remove one set from the other:
set_y << Remove( set_z );
Write( "\!N\!NDifference operation (set_z from set_y):\!N\!tset_y = ", set_y << Get Keys );
set_y = {"chair", "relay", "tripod"}
Intersect Operation
To find the intersection of two sets, use the aa << Intersect message.
set_y << Intersect( set_z );
Write( "\!N\!NIntersect operation (set_y, set_z):\!N\!tset_y = ", set_y << Get Keys );
set_y = {"person", "snake"}
Example of Using Set Operations
Given a list of names, which of them are not contained in Big Class.jmp? You can find the answer by taking the difference of the two sets of names.
1. Get the list of names and open the data table:
names list = {"ROBERT", "JEFF", "CHRIS", "HARRY"};
2. Put the list of names into an associative array:
names = Associative Array( names list );
3. Perform a difference operation by removing the column values from your list:
names << Remove( Associative Array( dt:name ) );
4. Look at the result:
Write( "\!NWhich of {ROBERT, JEFF, CHRIS, HARRY}, is not in Big Class = ", names << Get Keys );
Which of {ROBERT, JEFF, CHRIS, HARRY}, is not in Big Class = {"HARRY", "JEFF"}
