Predictive and Specialized Modeling > Boosted Tree > Boosted Tree Platform Options
Publication date: 03/03/2025
Image shown hereBoosted Tree Platform Options
The Boosted Tree red triangle menu contains the following options:
Show Trees
Provides options for displaying trees in the Tree Views report. The report gives a picture of the tree that is fit at each layer of the boosting process.
Plot Actual by Predicted
(Available only for continuous responses.) Shows or hides a plot of actual versus predicted values.
Column Contributions
Shows or hides a report of each input column’s contribution to the fit. The report also contains the following information:
– The total number of instances over all of the trees when the specified column is used to split the data.
– The total G2 (for a categorical response) or SS, sum of squares (for a continuous response) attributed to the column.
– A bar chart of G2 or SS.
– The proportion of G2 or SS attributed to the column.
ROC Curve
(Available only for categorical responses.) Shows or hides the Receiver Operating Characteristic (ROC) plot that contains a curve for each level of the response variable. If you used validation, a plot is shown for each of the training, validation, and test sets. See ROC Curve.
Precision Recall Curve
(Available only for categorical responses.) Shows or hides the Precision-Recall Curve plot that contains a curve for each level of the response variable. A precision-recall curve plots the precision values against the recall values at a variety of thresholds. If you used validation, a plot is shown for each of the training, validation, and test sets. See Precision-Recall Curve.
Lift Curve
(Available only for categorical responses.) Shows or hides the Lift Curve plot. If you used validation, a plot is shown for each of the training, validation, and test sets. See Lift Curve.
Decision Threshold
(Available only for binary categorical responses.) Shows or hides Decision Thresholds reports for the training, validation, and test sets, if specified. Each report contains a graph of the distribution of fitted probabilities for each model, confusion matrices for each model, classification graphs to compare the model fits, and a table of classification accuracy metrics. See Decision Thresholds Report.
Save Columns
Contains options for saving model and tree results, and creating SAS code.
Save Predicteds
Saves the predicted values from the model to the data table.
Save Prediction Formula
Saves the prediction formula to a column in the data table. The formula consists of nested conditional clauses that describe the tree structure. If the response is continuous, the column contains a Predicting column property. If the response is categorical, the column contains a Response Probability column property.
Save Tolerant Prediction Formula
(The Save Prediction Formula option should be used instead of this option. Use this option only when Save Prediction Formula is not available.) Saves a formula that predicts even when there are missing values and when Informative Missing has not been selected. The prediction formula tolerates missing values by randomly allocating response values for missing predictors to a split. If the response is continuous, the column contains a Predicting column property. If the response is categorical, the column contains a Response Probability column property. If you have selected Informative Missing, you can save the Tolerant Prediction Formula by holding the Shift key as you click the report’s red triangle.
Save Residuals
(Available only for continuous responses.) Saves the residuals to the data table.
Save Offset Estimates
(Available only for categorical responses.) Saves the sums of the linear components. These are the logits of the fitted probabilities.
Save Tree Details
Creates a data table containing split details and estimates for each layer.
Save Cumulative Details
(Available only if validation is used.) Creates a data table containing the fit statistics for each layer.
Publish Prediction Formula
Creates a prediction formula and saves it as a formula column script in the Formula Depot platform. If a Formula Depot report is not open, this option creates a Formula Depot report. See Formula Depot.
Publish Tolerant Prediction Formula
(The Publish Prediction Formula option should be used instead of this option. Use this option only when Publish Prediction Formula is not available.) Creates a tolerant prediction formula and saves it as a formula column script in the Formula Depot platform. If a Formula Depot report is not open, this option creates a Formula Depot report. See Formula Depot. If you have selected Informative Missing, you can use this option by holding the Shift key as you click the report’s red triangle.
Make SAS DATA Step
Creates SAS code for scoring a new data set.
Specify Profit Matrix
(Available only for categorical responses.) Enables you to specify profit or costs associated with correct or incorrect classification decisions. See Show Fit Details.
Profiler
Shows or hides a Prediction Profiler. See Profiler in Profilers.
See Local Data Filters in JMP Reports, Redo Menus in JMP Reports, Group Platform, and Save Script Menus in JMP Reports in Using JMP for more information about the following options:
Local Data Filter
Redo
Platform Preferences
Save Script
Save By-Group Script
