Publication date: 03/03/2025
Edit Items
You can perform the following tasks for items:
Note: The items associated with JMP provided common orderings cannot be changed.
• Add items to new and existing common orderings. In the field below the items box, type one item at a time and click Add Image shown here.
• Change the order of the items. Use the arrows to move the items and change the order in which they appear.
• Delete an item. To delete an item, click Delete Image shown here.
• Specify an exact match. Use the Exact Match option to indicate that the items must be identical. If this option is deselected, case and whitespace can be different.
