Essential Graphing > Contour Plots > Example of a Contour Plot
Publication date: 03/03/2025
To create a contour plot, you can use either the Contour platform or Graph Builder. This section provides examples for both.
• To see the example using the Contour platform, see Example Using the Contour Platform.
• To see the example using Graph Builder, see Example of a Contour Plot in Graph Builder.
