Design of Experiments Guide > Starting Out with DOE > Example of a Designed Experiment
Publication date: 03/03/2025
The following example uses DOE to examine the strength of brewed coffee. A less complex treatment of this example using the Easy DOE platform is described in “Example of the Easy DOE Platform”.
• Define the Study and Goals
• Create the Design
• Run the Experiment
• Analyze the Data
