Publication date: 03/03/2025
Exclude Columns in Data Tables
When your data table contains columns that you do not want to consider for analysis, you can exclude those columns so that they do not appear in selection lists in launch windows. Note the following:
• Excluded columns remain visible in the data grid.
• A circle with a strikethrough (Image shown here) appears to the right of the column name in the Columns panel.
To exclude columns from launch windows
1. Select one or more columns that you want to exclude.
2. Do one of the following:
– Right-click the highlighted column name in the Columns panel and select Exclude/Unexclude.
– From the Cols menu, select Exclude/Unexclude.
To unexclude columns
1. Select the columns in the Columns panel.
