Multivariate Methods > Item Analysis
Publication date: 03/03/2025
Item Analysis
Analyze Test Results by Item and Subject
The Item Analysis platform enables you to fit item response theory models. The Item Response Theory (IRT) method is used for the analysis and scoring of measurement instruments such as tests and questionnaires. Item response theory (IRT) uses a series of equations to relate items to an unobserved (latent) trait or ability. Items, or questions, are indicators of an underlying latent construct that cannot be directly observed. At the time of data collection, both the subject abilities and the item characteristics are unknown. IRT can be used to study standardized tests, cognitive development, and consumer preferences. IRT is an alternative method to classical test theory (CTT) where the focus is on the total observed score rather than the item scores.
The Item Analysis platform implements the IRT method with the following outcomes:
• Measurement instruments are scored at the item level, providing insight into the contributions of each item on the latent response.
• Scores for both the responders and the items are produced on the same scale.
• Respondent and item scores are shown on a single plot.
• Item characteristic curves are shown. These curves can be used to explore the relationship between items and respondent’s underlying trait or ability.
For more information about item response theory, see de Ayala (2009).
Figure 12.1 Item Analysis Characteristic Plot
Contents
Example of Item Analysis
Launch the Item Analysis Platform
Logistic 3PL Model Details
Data Format
The Item Analysis Report
Characteristic Curves
Information Plot
Dual Plot
Parameter Estimates
Item Analysis Platform Options
Statistical Details for the Item Analysis Platform
Statistical Details for Item Response Curves
Statistical Details for Item Response Curve Models
Statistical Details for IRT Model Assumptions
Statistical Details for Fitting the IRT Model
Statistical Details for the Ability Formula
