Using JMP > JMP Technical Details > JMP Features That Support Multithreading
Publication date: 03/03/2025
Some features in JMP are coded to take advantage of multiple central processing units (CPUs) on a machine, allowing these features to run significantly faster. This process is called multithreading.
The following features support multithreading:
• Image shown here Boosted Trees
• Image shown here Bootstrap Forest
• Choice
• Image shown here Covering Arrays
• Capability Analysis in Distribution
• Explore Outliers
• Explore Patterns
• Factor Analysis
• Fit Life by X
• Fit Model: Parametric Survival, Image shown here Mixed Model, Image shown here Generalized Regression, and Image shown here Response Screening
• Functional Data Explorer
• Gaussian (Image shown here Fast GASP and the use of Categorical variables are only in JMP Pro.)
• Image shown here K Nearest Neighbors
• Latent Class Analysis
• Life Distribution
• Multivariate
• Neural (Image shown here Some features are only in JMP Pro.)
• Nominal Logistic
• Nonlinear and Nonlinear Curve
• Normal Mixtures in Cluster Analysis
• Partial Least Squares (Image shown here Some features are only in JMP Pro.)
• Partition
• Predictor Screening
• Principal Components
• Process Screening
• Profiler (Does not apply to Profilers launched from within other platforms.)
• Reliability Forecast
• Image shown here Repairable Systems Simulation
• Response Screening
• Image shown here Sparse Principal Components
• Image shown here Structural Equation Models
• Image shown here Support Vector Machines
• SVD Imputation in the Missing Values Screening
• Text Explorer (Image shown here Some features are only in JMP Pro.)
• Time Series Forecast
• Image shown here Uplift
• Variable Clustering
