Welcome to JMP > Learn about JMP > JMP Online Help
Publication date: 03/03/2025
JMP Online Help
The JMP Online Help enables you to search for information about JMP features, statistical methods, and the JMP Scripting Language (JSL). You can open JMP Online Help several ways:
• On Windows, select Help > JMP Online Help.
• On macOS, select Help > JMP Help.
• On Windows, press the F1 key.
• To get help on a specific part of a data table or report window, select Help > Help Tool. Then, click anywhere in a data table or report window. To dismiss the Help tool, press the Esc key.
• Within a JMP window, click the Help button.
Note: The JMP Help is available for users with internet connections. Users without an internet connection can install the documentation add-in. See Documentation PDF Add-in for more information.
