Publication date: 03/03/2025
K Means Report
When you click Go in the Control Panel, a cluster comparison report and one or more K Means reports appear. The K Means reports are dynamically named K Means NCluster=<k> depending on, k, the number of clusters fit. A K Means NCluster=<k> report appears for each fit that you conduct.
• Cluster Comparison Report
• K Means NCluster Reports
