Profilers > Custom Profiler > Launch the Custom Profiler Platform
Publication date: 03/03/2025
The Custom Profiler can be accessed from the Graph menu or the red triangle menus of certain platforms.
• The Custom Profiler can be accessed directly from the Graph menu. When you access the Custom Profiler in this way, the Custom Profiler launch window appears. See Profiler Launch Windows.
• The Custom Profiler can be accessed as a red triangle menu option in many modeling platforms. See Where to Find JMP Profilers for more information about the availability of the Custom Profiler in different platforms.
• The Custom Profiler can be accessed from the Model Comparisons platform. Select Profiler from the Model Comparisons red triangle menu. Then, select Custom Profiler from the Profiler red triangle menu.
• Image shown hereThe Custom Profiler can be accessed from the Formula Depot platform. Select Profiler from the Formula Depot red triangle menu and select the models to be profiled. Then, select Custom Profiler from the Profiler red triangle menu.
