Profilers > Mixture Profiler > Launch the Mixture Profiler Platform
Publication date: 03/03/2025
The Mixture Profiler can be accessed from the Graph menu or the red triangle menus of certain platforms.
• The Mixture Profiler can be accessed directly from the Graph menu. When you access the Mixture Profiler in this way, the Mixture Profiler launch window appears. See Profiler Launch Windows.
• The Mixture Profiler can be accessed as a red triangle menu option in many modeling platforms. See Where to Find JMP Profilers for more information about the availability of the Mixture Profiler in different platforms.
• The Mixture Profiler can be accessed from the Model Comparisons platform. Select Profiler from the Model Comparisons red triangle menu. Then, select Mixture Profiler from the Profiler red triangle menu.
• Image shown hereThe Mixture Profiler can be accessed from the Formula Depot platform. Select Profiler from the Formula Depot red triangle menu and select the models to be profiled. Then, select Mixture Profiler from the Profiler red triangle menu.
