Quality and Process Methods > Pareto Plots > Pareto Plot Platform Options
Publication date: 03/03/2025
The Pareto Plot red triangle menu contains options to perform different types of count analyses.
Configure Causes
Shows a window that contains options to customize one or more of the individual bars in the Pareto plot. You can change the label, color, and marker of individual causes and specify if the bar value is shown. You can also combine, separate, or reorder the causes.
Per Unit Rates
Shows or hides a table that compares defect rates across groups. If a sample size is specified in the launch window, Defects Per Unit (DPU) and Parts Per Million (PPM) columns are included in the Per Unit Rates table.
Test Rate Within Groups
Shows or hides a table of the results of a likelihood ratio chi-square test to determine whether the rates across causes are the same within a group. See Statistical Details for the Pareto Plot Platform.
Test Rates Across Groups
(Available only when a Grouping variable is specified in the launch window.) Shows or hides a table of the results of a likelihood ratio chi-square test to determine whether the rate for each cause is the same across groups. See Statistical Details for the Pareto Plot Platform.
Note: By default, the statistics shown in the tables are calculated based on the raw counts of causes and do not take into account causes that have been combined or ordered in the Pareto plot. To calculate the statistics in a table based on the counts of causes as shown in the Pareto plot, select the Match Plot option from the corresponding table’s red triangle menu. If you press Ctrl and select the Match Plot option, the option is applied to all of the tables in the report.
See Local Data Filters in JMP Reports, Redo Menus in JMP Reports, Group Platform, and Save Script Menus in JMP Reports in Using JMP for more information about the following options:
Local Data Filter
Redo
Platform Preferences
Save Script
Save By-Group Script
