Publication date: 03/03/2025
Relative Efficiency Measures
Notation
• X is the model matrix
• p is the number of terms, including the intercept, in the model
• Equation shown here is the relative prediction variance at the point Equation shown here. See Relative Prediction Variance.
Relative Efficiencies
The relative efficiency of the reference design (Ref) to the comparison design (Comp) is given by the following expressions:
D Efficiency
EffRef / EffComp, where Eff for each design is given as follows:
Equation shown here
G Efficiency
EffComp / EffRef, where Eff for each design is given as follows:
Equation shown here
Here, D denotes the design region.
Note: G-Efficiency is calculated using Monte Carlo sampling of the design space. The reported value is based on the larger of Equation shown here or the prediction variance from the Monte Carlo sampling. Therefore, calculations for the same design might vary slightly.
A Efficiency
Equation shown here
I Efficiency
Equation shown here
For more information about the calculation, see Section 4.3.5 in Goos and Jones (2011).
