Publication date: 03/03/2025
Rename Data Tables
A data table’s name appears at the top of its window, in the table panel, and on all related analysis reports. You can change a data table’s name in any of the following ways:
• Select File > Save As and save as the new name.
• In the table panel, click table name, type the new name, and then press Enter.
• On Windows, select Window > Set Title.
