Reliability and Survival Methods > Repairable Systems Simulation > Simulation Results > Repairable Systems Simulation Results Options
Publication date: 03/03/2025
Image shown hereRepairable Systems Simulation Results Options
The Repairable Systems Simulation Results red triangle menu contains the following options:
Point Estimation of Component Availability
For each block shape in the system diagram, this option shows the following reports:
– Point Estimation of Availability Profiler
– Available Time Distribution
– Availability Distribution
– Point Estimation of Unplanned Outage Profiler
– Unplanned Outage Time Distribution
– Unplanned Outage Distribution
Box Plot of System Total Downtime by Component
Shows a box plot of the total time the system was in the Down or Off states caused by individual components. The components are ordered by contribution from the most outage time to the least outage time, similar to a Pareto chart.
Box Plot of System Unplanned Total Outage Time by Component
Shows a box plot of total time the system was in the Down state caused by individual components. The components are ordered by contribution from the most outage time to the least outage time, similar to a Pareto chart.
See Redo Menus in JMP Reports, Group Platform, and Save Script Menus in JMP Reports in Using JMP for more information about the following options:
Redo
Platform Preferences
Save Script
Save By-Group Script
Image shown hereResults Explorer Point Estimation Profiler Options
Each point estimation profiler within the Repairable Systems Simulation Results Explorer report has a red triangle menu that contains the following options:
Confidence Intervals
Shows or hides the 95% confidence intervals on the point estimation graphs.
Reset Factor Grid
Opens the Factor Settings window, which enables you to modify the parameters of the point estimation graph. See Reset Factor Grid in Profilers for more information about setting the factor grid.
Factor Settings
Provides additional options affecting the Factor Grid. See Factor Settings in Profilers for more information about Factor Settings.
