Profilers > Surface Plot > Surface Plot Platform Options
Publication date: 03/03/2025
The Surface Plot red triangle menu contains the following options:
Control Panel
Shows or hides the Control Panel, which includes the controls for Appearance, Independent Variables, and Dependent Variables.
Scale response axes independently
Scales response axes independently. See Launch the Surface Plot.
Fit to Window
Determines whether the plot is resized as you resize the report window.
Auto (default)
Bases the scaling on the contents of the plot. For example, a plot with By variables or used as a Surface Profiler in a Fit Model platform does not stretch to fit the resized window; the plot extends beyond the viewing area.
On
Always fits the plot inside the window.
Off
Prevent the plot from resizing.
See Local Data Filters in JMP Reports, Redo Menus in JMP Reports, Group Platform, and Save Script Menus in JMP Reports in Using JMP for more information about the following options:
Local Data Filter
Redo
Platform Preferences
Save Script
Save By-Group Script
