Using JMP > Workflow Builder > Technical Details for the Workflow Builder
Publication date: 03/03/2025
The following are technical notes about the Workflow Builder.
Notes:
• The Workflow Builder uses actions captured in the Enhanced Log. Use the custom option in the Step Settings to add JSL for steps not automatically captured.
• The JMP Log History captures activity from the start of the JMP session, regardless of when the Workflow Builder is opened.
• If you add an action from the Enhanced Log and there is more than one Workflow Builder open, it adds the step to the topmost builder.
• Workflow Builder runs within projects.
• As the workflow executes, each step is evaluated before it is run. If a hardcoded table path is found and the table is not open, the user is prompted to open the table or one that is compatible to continue the workflow. Similarly, if an unknown column references is found, the user is prompted for a replacement. This is limited to 1-1 replacement. It does not work well for a large number of column replacements.
• When publishing to JMP Live or JMP Public, ensure that the report step is ahead of the publish step in the workflow.
