Using JMP > Workflow Builder > The Workflow Builder Window
Publication date: 03/03/2025
The Workflow Builder Window has three sections. The Workflow Steps is where you view and arrange your workflow steps. The Step Settings is where you can edit and add advanced actions to your steps. The JMP Log History is a history of your JMP session.
• Workflow Steps
• Step Settings
• JMP Log History
