Predictive and Specialized Modeling > Time Series Forecast > Time Series Forecast Platform Options
Publication date: 03/03/2025
The Time Series Forecast red triangle menu contains the following options:
Report Options
(Effective only after fitting a model.) Contains the following report options:
Set Forecast Interval Level
Enables you to change the forecast interval level. The individual model reports update automatically.
Set NAhead
Enables you to change the number of steps ahead to forecast. The individual model reports update automatically.
Set NHoldout
Enables you to change the duration of the holdout set. The individual model reports update automatically.
Save Results
(Effective only after fitting a model.) Saves the forecasts to a separate data table named Forecasts. The Forecasts data table has the same layout and format as the original data table. If a holdout set is specified by NHoldout, an additional data table that saves the actual values from the holdout data and the forecasts is produced. You can use this table to calculate different types of error estimates.
The following additional save options are shown in the Request Outputs window:
Save Forecast Intervals
Saves the lower and upper prediction intervals as columns in the Forecasts data table.
Save One-Step-Ahead Predictions
Stacks the one-step-ahead predictions and the forecasts and saves them to a separate data table.
Save Original Series
Stacks the original series and the forecasts and saves them to a separate data table.
Save Forecast Results to Original Data Table
Saves the results to new columns in the original data table.
See Local Data Filters in JMP Reports, Redo Menus in JMP Reports, Group Platform, and Save Script Menus in JMP Reports in Using JMP for more information about the following options:
Local Data Filter
Redo
Platform Preferences
Save Script
Save By-Group Script
