Scripting Guide > JSL Building Blocks > Rules for Name Resolution > Troubleshoot Variables and Column Names
Publication date: 03/03/2025
In JSL, when you reference a column name using As Name(), and Names Default To Here( 1 ) is set, JMP returns a variable reference. That reference is then processed using the standard reference rules.
In the following example, there is no height variable in the Here: scope, so JMP returns an error.
Names Default To Here( 1 );
Open( "$SAMPLE_DATA/Big Class.jmp" );
As Name( "height" )[3]; // converts height to a variable reference
As Name( "height" )[/*###*/3];
The /*###*/ characters in the log indicate the location of an error in the script execution.
To prevent this problem, use one of the following methods:
• Use As Column() instead of As Name():
As Column( "height" )[3]; // converts height to a data column reference
• Explicitly scope height with As Name():
dt:( As Name( "height" ) )[3]; // scopes height as a data column reference
These scripts return 55, the value of height in the third row of Big Class.jmp.
