Using JMP > JMP Reports > Use Markers in JMP Graphs
Publication date: 03/03/2025
Markers are points on a graph that represent data. Once they are changed from their default setting, they also appear next to rows in the data table.
• Change the Shape of Markers
• Change the Color of Markers
• Change the Size of Markers
• Work with Crowded Markers
• Add Outlines Around Markers
• Change the Selection Mode of Markers
• Specify the Transparency of Markers
• Exclude and Hide Markers
• Use Images as Markers
• Change the Shape or Color of Markers Based On Values
