Using JMP > JMP Reports > Navigate JMP Reports > Use the Hand Tool
Publication date: 03/03/2025
Use the Hand Tool
Select the hand tool using the Tools > Grabber option. There are many functions that you can use with the hand tool (also known as the grabber tool) in a report. Here are some examples of how the hand behaves in graphs and plots:
• On histograms, for continuous variables, use the hand tool to change the number of bars or to shift the boundaries of the bars.
• In all report tables, use the hand tool to click and drag columns for rearranging.
• Use the hand tool to change the displayed range of axis values. See Scroll and Scale Axes in Graphs.
