Using JMP > Get Started with JMP > Manage Files and Open Windows > Use the Windows Reveal Feature
Publication date: 03/03/2025
The Reveal feature shows a top-level window with thumbnails of all open JMP windows. On Windows, press F9 to use the Reveal feature.
• Click a window to activate it.
• Press the spacebar to turn on Preview mode, where a full-sized view of the thumbnail under the cursor appears in the center of the screen.
• By default, the windows are ordered to match the original ordering on the screen in a top-down, left-to-right order. Press S to sort the thumbnails by name.
To exit the Reveal feature, press F9, Esc, or Alt+Tab and then select another application.
