Discovering JMP > Work with Your Data > Work with Data Tables
Publication date: 03/03/2025
This section describes the basic concepts for working with data tables.
• Edit Data in a Data Table
• Select, Deselect, and Find Values in a Data Table
• View or Change Column Information in a Data Table
• Example of Calculating Values with Formulas
• Example of Filtering Data in a Report
Tip: Consider setting the Autosave timeout value in the General preferences to automatically save open data tables at the specified number of minutes. This autosave value also applies to journals, scripts, projects, and reports.
