Using JMP > Platform Presets > Copy and Paste Preset Settings
Publication date: 07/15/2025
You can use the Copy Settings and Paste Settings menu options to apply customizations to another platform, regardless of whether a platform’s customizations were saved as a preset.
Select Copy Settings from the source report and then Paste Settings in the target report.
If the Paste option is not available, the target platform is not compatible with the copied settings.
Drag and Drop
You can also drag the Platform Preset icon to another compatible report to apply the customizations in the source platform to the target platform. If the customizations are not applied, the platform is not compatible.
