Life Sciences > Normalization > Example of Normalization
Publication date: 07/15/2025
Learn how to normalize the data in a JMP table.
This example uses a small subset of the Drosophila aging experiment data from (Jin, Riley et al. 2001). The drosophilaaging_JMP_table.zip file containing the drosophilaaging.jmp table used in this example, can be downloaded from here and saved to your computer.
1. Open a suitable JMP table or other data set in JMP.
2. Select Analyze > Life Sciences > Normalization.
3. Select all of the data columns (col.2 through col.49) and click Y, Columns.
4. Check Create New Tables for Results.
5. Click OK.
Figure 8.1 Table containing the Normalized Data
