Using JMP > Import Your Data > Import Data from an AspenTech InfoPlus.21 Server
Publication date: 07/15/2025
Time series data for industrial processes, such as process monitoring and control, can be imported from an AspenTech InfoPlus.21 (IP.21) server using the JMP import function.
