Using JMP > Save and Share Your Data > Create Journals > Right-Click Options in Journals
Publication date: 07/15/2025
Add Outline Item
Groups text and links into collapsible and expandable lists.
Add Text Item
Allows you to enter up to six paragraphs with the option to add a bullet or hide the text. To unhide, right-click the hidden text and deselect Hide.
Note: To add text outside of an outline level, you can also double-click at the end of the journal and enter text in the box that appears. Click outside of the box to exit the editing mode.
Add Window Reference
Creates a link to a window that is already open in JMP.
Add File Reference
Creates a link to a file on your computer.
Add Directory of Files
Creates links to all files (including non JMP files) in the selected directory.
Add Open Files
Creates outline levels and links to open files in JMP (except for the log). For example, a link to the open Big Class.jmp data table and chart is displayed below a collapsible header named Big Class. Files such as journals and scripts are grouped below a collapsible header called Other Files.
Add URL Reference
Creates a link to files that are delivered through an internet protocol such as HTTP, FTP, or FILE://.
Add Script Button
Creates a link to a JSL script. Right-click the link and deselect Underline Style to display the link as a button.
Add Script Box
Adds a box in which you enter a script.
Lock
Hides the journal toolbar and insertion cursor. If you select Edit > Journal from a platform, the results are not appended to a locked journal.
Edit Links
Enables you to rename file links (for example, to remove a hardcoded path). An option to test links is also provided. If the path is valid, nothing happens when you click Test Links. If the path is not valid, an error message appears in the log. To update an invalid link, click Replace.
Size to Fit
Resizes the window to ensure that button names are fully displayed.
